Need help for On change client script and Script include to print data
Divya Kandula
Hi Need help for below client script and Script Include
Client Script:
    var code = g_form.getValue('u_commodity_code');
    if (g_scratchpad.isGreenLaneRecord == true) {
        var desc = new GlideAjax('FJS_DeclarationGoodsUtilsAjax');
        desc.addParam('sysparm_name', 'getCommodityHierarchy');
        desc.addParam('sysparam_code', code);
        desc.getXML(hierarchyDesc);
    function hierarchyDesc(response) {
        g_form.setValue('u_commodity_code_hierarchy', answer);
Script Include:
getCommodityHierarchy: function() {
		var code = this.getParameter("sysparam_code");
        var comHierarchy = '';
        var goodsDesc = '';
        var grCC = new GlideRecord('sn_customerservice_commodity_code');
        grCC.addEncodedQuery('u_commodity_code' + code); //u_goods_descriptionSTARTSWITHOther^
        grCC.query();
        if (grCC.next()) {
            var hierDesc = grCC.u_hierarchy_description;
            comHierarchy = hierDesc.replace(/[||]+/g, '\n');
            goodsDesc = grCC.u_goods_description;
        var Desc = 'Commodity Code: ' + code + '\n' + 'Commodity Code Description: ' + goodsDesc + '\n' + 'Hierarchy Description: ' + '\n' + comHierarchy;
		return Desc;
i need  to set "u_commodity_code_hierarchy" value with three fields from sn_customerservice_commodity_code table. Please help
Divya Kandula
Creating Desc variable in both client script and Business rule caused the issue.
AshishKM
Hi @Divya Kandula ,
What is the type of this field "u_commodity_code_hierarchy" single line/or/multi line.
Try with return Desc.toString(); in script include and test.
-Thanks,
AshishKM
It is a multi line string
return Desc.toString(); dint work
Divya Kandula
