Need Help on how to use IndexOf in below query.
Alok21
Giga Expert
Hi Team,
Need your assistance on below query.
I am trying to set a condition for notification to get triggered. I am now got stuck on how to use indexOf in below gliderecord query. So what i am trying to compare is, When the catalog is "Technical Catalog", notification should not be sent. Below is the script i have and it is triggering even for "Technical Catalog" which it should not.
Can anyone please help on this, what am i doing wrong?
answer = true;
var gr = new GlideRecord("sc_req_item");
gr.addQuery("request", current.sys_id);
if (gr.next()) {
if (gr.cat_item.sc_catalogs == indexOf(gs.getProperty("tc.item.catalogs.type")));
answer = false;
Alok kumar sahu
Ashutosh Munot1
HI,
If the value exist then it will return its position and if it does not then it will return -1.
So we have to compare that as well. Use below code:
if(gr.cat_item.sc_catalogs.indexOf(gs.getProperty("tc.item.catalogs.type")) >-1)
//THis means if the value in gr.cat_item.sc_catalogs is present in ur property then it will enter if loop.
Ashutosh
prasannaposetty
Hi Alok,
Try creating the notification on Requested Item table (sc_req_item) and in the conditions you can directly mention, Catalog is not Technical Catalog.
Prasanna
