PDI Technical Issue
YuvrajS90374537
I just got a new personal instance on yokohama version...and wanted to install CSM plugin. At first i searched for it and started installing but after a while when i searched again to see the progress it showed 0 results.
But when i switch to classic view I am seeing all the plugins i search for.
Does anyone know why this would happen or is facing the same issue with their PDI's.
Screenshot 2025-07-14 at 11.38.42 AM (2).pngScreenshot 2025-07-14 at 11.44.23 AM.png
Hey @SD_Chandan....thanks , but i have already activated it from the classic view where i faced no problem.
hey @glideFather I am able to find the plugin in the classic view...just that the plugins aren't showing up in the new UI.
Thanks.
AHaaa, now I understand it.
I wanted to replicate, for the first time I also couldn't see it in the new UI but could see in the "old" one. But then I refreshed and used another admin (PDI) and it was found in the new UI for the second attempt... but second not first, not sure why...
Have you happened to install it in the end?
✂-----Cutting-out-the---✦AI-noise✦---All-replies-written-and-vouched-for-by-GlideFather---
Thanks @glideFather for trying it out.
SD_Chandan
Hi @YuvrajS90374537 ,
You can try activate it from home screen
I think it should work & There is no support available for PDI.
Thank you
Chandan
I tried this as well but the demo plugin was not listed there 😞 while PDI is exactly the place where I would expect to find demo plugins hehe
