Reject Solution case
Lorex
i want to know if there is a way to make mandatory a comment when a customer click on reject solution button. I need because OOTB a customer can reject a CASE resolution without explaining why he is rejetcing the case resolution.
I asked some days ago here in the community, and the suggestion was "modify the UI Action as follow":
This is the script:
new global.StateFlow().processFlow(current, '05a03d27c3123100d6d210c422d3ae18', 'manual');
current.state = 'rejected';
if(!JSUtil.nil(current.comments))
current.update();
else{
gs.addErrorMessage("Comments are required when rejecting an approval");
current.state = 'requested';
current.setAbortAction(true);
function markclose()
g_form.setMandatory('comments',true);
gsftSubmit(gel('checkcomments'));
But, the button is still not working. No comments are mandatory if i reject case resolution.
Can you help me?
Best regards,
Lorex
Can you try using below once
function markClose()
alert('To check'); //can be commented if required
markingclose();
function markingclose()
current.update();
/*if(!JSUtil.nil(current.comments))
else
Hey Jaspal. Thank you for your time.
It doesn't work 😞
Lorex
It doesn't work 😞
