4/10 Q. ITOM Project Help !! (Please No Paste CHATGPT ANSWER)
SandeepKSingh
I must ensure Discovery and outbound integrations keep running even if one MID Server goes down. How we can Build a high-availability  + failover setup for two (or more) MID Servers across the same network, so that:
  • Jobs are load-balanced during normal operation.
  • If MID-A fails, jobs auto-failover to MID-B (and vice-versa) with minimal disruption.
  • The design remains upgrade-safe and easy to support.
2 ACCEPTED SOLUTIONS
Ravi Gaurav
Hi @SandeepKSingh
As you must be knowing
Every MID Server sends a heartbeat to the ServiceNow instance (by default every 40 seconds).
If that heartbeat stops coming in (because the service crashed, server rebooted, or network broke), ServiceNow marks the MID as Down.
You can see this in MID Servers > Status (shows Up, Down, Validate).
According to me You must ensure Discovery and outbound integrations keep running even if one MID Server ...goes down.
Example :
MID-A and MID-B: Same site/subnet
Selection method: MID Server Cluster.
Cluster: the one containing MID-A and MID-B.
Keep IP ranges common to the cluster (no hard-binding to a single MID).
Configure monitoring/notifications when a MID goes Down (e.g., notify NOC if heartbeat older than X minutes).
@Ravi Gaurav
As per my understanding, it is not mandatory to setup heartbeat and MID Server cluster configuration is enough for failover to work.
You can refer Business Rule 'MID Server Cluster Management' for more information on the logic.
https://www.servicenow.com/docs/bundle/zurich-servicenow-platform/page/product/mid-server/reference/...
https://noderegister.service-now.com/kb?id=kb_article_view&sysparm_article=KB0661756
https://www.servicenow.com/docs/bundle/zurich-servicenow-platform/page/product/mid-server/concept/c_...
Monitoring heartbeat, failed jobs and job status in ServiceNow MID Server Dashboard is useful for tracking overall health of MID Servers.
If this helped to answer your query, please mark it helpful & accept the solution.
Bhuvan
11 REPLIES 11
The heartbeat works.. OOTB business rule as uses internally Mid server is up or down.. but as suggested @Ravi Gaurav  the system logs has heartbeat.. that helped me 🙂
SandeepKSingh
Thanks @Bhuvan  and @Ravi Gaurav  that's really a good Discussion !!
