A Simple Flow If Statement is Evaluating to False
09-19-2025 07:13 AM
I have a Sub Flow with an input variable for addRemove. I am passing "add" to it and it evaluates in the If statement to Add=Add, but is still evaluating to False. I have tried various upper and lowercase possibilities such as Add, add, "Add", "add".
What am I missing here? This seems like it should be pretty simple.
09-19-2025 08:33 AM
yes sometimes it behaves weird especially when it comes to action/subflow inputs.
try to re-create the subflow again.
09-19-2025 07:46 AM
Sometimes Flow behaves unpredictably; try removing the step, clearing the cache, and then re-adding it. Also, check the thread below, it might give you some useful pointers.
Using iterative/enumerated comparisons (Choice/Boolean/Integer) is generally much more reliable than plain string checks, since it avoids issues with casing or hidden whitespace. So it’s worth giving that approach a try.
Thanks & Regards,
Muhammad Iftikhar
If my response helped, please mark it as the accepted solution and helpful so others can benefit as well.
