ABC group members is not part of Level 1 and Level 2 cost center users
raj149
Giga Guru
Hello Experts,
My requirement is
I want users details in a report who is part of ABC group is not part of  cost center table Level1 approver(reference field) and level 2 approver(reference field).
So I created script include but when i run report it is taking so much of time to get results and instance also not working
In report the condition is sysID is javascript: TestL1L2Approver();
Is there any mistake in my script
function TestL1L2Approver(){
mem =[];
var grMembers = new GlideRecord('sys_user_grmember');
    grMembers.addQuery('group' ,'e5302b2d1b4e11506ece2fc5604bcb5c');
    grMembers.query();
    while (grMembers.next()) {
        var userSysID = grMembers.user.toString();
        var Levelone = new GlideRecord('cmn_cost_center');
        Levelone.addQuery('u_level_1_approver', userSysID);
        Levelone.query();
        while (!Levelone.next()) {
            var Leveltwo = new GlideRecord('cmn_cost_center');
            Leveltwo.addQuery('u_level_2_approver', userSysID);
            Leveltwo.query();
            while(!Leveltwo.next()) {
                mem.push(grMembers.user);
return mem;
Best Regards,
Raj
15 REPLIES 15
@raj149
is the script include client callable and in same scope as that of the report?
Certified Technical Architect  ||  9x ServiceNow MVP  ||  ServiceNow Community Leader
Hello @Ankur Bawiskar
Yes client callable and same scope.
@raj149
did you try running the same script in background and check if the array contains any users?
Now if I run report, I can see only one user sys_id is coming but he is part of L1 approver. I changed the condition as well . But no luck.
Please help me to achieve this requirement
Best Regards,
Raj
@raj149
try this
function TestL1L2Approver() {
	var mem = [];
	grMembers.addQuery('group', 'e5302b2d1b4e11506ece2fc5604bcb5c');
	grMembers.query();
		Levelone.query();
		while(Levelone.next()){
			if(Levelone.u_level_1_approver != userSysID && Levelone.u_level_2_approver != userSysID)
				mem.push(grMembers.user.toString());
	return mem;
