08-10-2025 06:04 AM - edited 08-10-2025 06:06 AM
Here is the requirement:
1.Here is the code snippet ACL I have created for change_request table
var loggedInUser = gs.getUser().getCountry();
var callerCountry = current.requested_by.country;
var locationCountry = current.cmdb_ci.location.country;
if (
loggedInUser == 'BBB' || loggedInUser == 'CCC'
if (callerCountry == 'AAA' && locationCountry == 'AAA') {
answer = false;
answer = true;
answer = true;
2.I need to build the same ACL for "Problem" but the requirement states:
For Problem records, the restriction is based on two checks:
(i) If the "first_reported_by_task" field is populated and refers to an Incident record, check the caller_id.country of that Incident.
(ii) If the "first_reported_by_task"is not populated, check the opened_by.country on the Problem record.
If either country value is "AAA", users from countries "BBB" or "CCC" should not be able to view the record.
I tried using the same logic as change by dot -walking, but still access is granted. Please help me with this !
08-11-2025 08:25 AM
Hello, could you please try below and share the outcome?
// Get the logged-in user's country
var loggedInUserCountry = gs.getUser().getCountry() + '';
// List of restricted countries
var restrictedCountries = ['BBB', 'CCC'];
// Default allow
answer = true;
// Only apply restriction if user is from restrictedCountries
if (restrictedCountries.indexOf(loggedInUserCountry) > -1) {
var blockAccess = false;
var frbt = current.first_reported_by_task;
if (frbt && frbt.sys_class_name == 'incident' && frbt.caller_id.country.toString() == 'AAA')
blockAccess = true;
// No first_reported_by_task → check opened_by country
else if (current.opened_by.country.toString() == 'AAA')
blockAccess = true;
if (blockAccess)
answer = false;
Nishant
08-10-2025 09:39 AM
Okay, Then try below code snippet.
(function() {
answer = true;
var countryUsr = "";
if (!gs.nil(current.first_reported_by_task)){
if (current.related_incidents > 0) {
var gr = new GlideRecord('incident')
gr.addQuery('problem', current.sys_id)
if (gr.next()) {
gr.caller_id //now you got the caller ID
var g = new GlideRecord('cmn_location')
if (g.get(gr.location))
countryUsr = g.country
else
countryUsr = current.opened_by.country //This is for if "first_reported_by_task" field is populated but no incident record then use the opened by
else {
//We now have the country code, just check the conditions
if (countryUsr == "AAA"){
if(loggedInUser =="BBB" || loggedInUser =="CCC")
answer = false
Just cross check the variable names and comparison with the literal values.
Bhimashankar H
If my response points you in the right directions, please consider marking it as 'Helpful' & 'Correct'. Thanks!
08-11-2025 08:25 AM
// Default allow
answer = true;
blockAccess = true;
blockAccess = true;
if (blockAccess)
answer = false;
Nishant
08-12-2025 12:49 AM
Hi @Nishant8 , Thank you so much ! It helped.
But I'm unable to open the Incident record in the "first reported by" field.
I have checked the Incident record."User belong to Brazil location only" so BBB should ableto view the Incident righ?
Can you please let me know what is the cause of this. I have attached the screenshot
I have written Before "query" Business Rule:
Please let me know. whether any changes I should make?
if (loggedInUser == 'BBB' || loggedInUser == 'CCC' ) {
current.addEncodedQuery('opened_by.country!=AAA^ORfirst_reported_by_task.ref_incident.caller_id.country!=AAA');
})(current, previous);
08-12-2025 07:45 AM
Hello @Sruthi_2511, Glad that previous solution helped you.
We configured the previous ACL on problem, which shouldn't cause any problem for Incident records... Do you receive any error while opening the Incident or any security is preventing you to see that Inc record (you missed to attach the screenshot)? Could you please try below once:
- Try to open the same INC record directly and verify whether you open it successfully
- If no error and any ACL is preventing you to open, please review existing ACL
Also, which table this before query BR is configured to run on? I'm not sure what you are trying to achieve with shared BR, but your encodedQuery doesn't seem to be used correctly. If you share exact requirement, probably I can help you write the same.
Nishant
08-12-2025 08:06 AM
Hi there @Sruthi_2511
you can’t always dot-walk directly to caller_id.country—you first need to confirm the referenced record type. A practical approach is to check if first_reported_by_task exists, get its referenced record, confirm it’s an Incident, and then pull the caller’s country. If that field isn’t populated, fall back to opened_by.country on the Problem itself. Once you have the target country, simply block access for users from “BBB” or “CCC” if the country matches “AAA.
If this helps kindly accept the solution thanks.
Kind Regards,
Azar
Serivenow Rising Star ⭐
Architect@ KPMG.
