Advanced Reference Qualifier Based-On Current Variable
01-22-2018 08:45 AM
Need help setting-up an advanced reference qualifier that uses the 'u_term_code' field from the *Term drop-down as a dependency and returns a list of courses that share the value.
javascript: u_term_code = current.variables.u_term_code;
Above, is the code I currently have.
01-23-2018 01:44 PM
01-23-2018 01:55 PM
Ok Great
So you need reference qualifier in course as
javascript: 'u_term_code = '+current.variables.u_term_code;
And In the default tab of course add
ref_qual_elements= u_term_code
01-24-2018 06:55 AM
Thanks for all the help, Sanjiv! Unfortunately, I am still unable to return any results from the form in the Service Portal. I added ref_qual_elements= u_term_code to the variable attributes field in the Default tab, to no avail.
01-24-2018 09:13 AM
Ok. Can you add this to attribute in your term variable
ref_qual_elements= your_course_variable_name
01-24-2018 12:09 PM
I tried that and still nothing. I am using the variable name from the form in the code snippet you provided, and it still doesn't return any courses. I feel like we're close to where we need to be, but just missing one thing.
