Advanced Reference Qualifier Based-On Current Variable
codechaser
Giga Expert
Need help setting-up an advanced reference qualifier that uses the 'u_term_code' field from the *Term drop-down as a dependency and returns a list of courses that share the value.
javascript: u_term_code = current.variables.u_term_code;
Above, is the code I currently have.
47 REPLIES 47
Can you provide me the variable name of Term and Course in your catalog item?
Ok. This is what you need
Reference Qualified on Course
javascript: 'u_term_code = '+current.variables.term_req;
And variable attribute In the default tab of course
ref_qual_elements= term_req
You can remove the variable attribute from Term, if you have any.
Hi Sanjiv,
Sorry for the delayed response!   I tried what you said, above and still nothing.   What I am envisioning is if term_code from 'Table A' = term_code from 'Table B', then return this set of courses.   I don't know what else to try.   So, if you have anything else up your sleeve, feel free to comment below.
I think it should work fine.
Another option you can try is u_term_code is javascript: 'u_term_code = '+current.variables.term_req;
