Advanced reference qualifier not working as expected
ramak
Giga Expert
Hello all, there is a requirement that restricts the users based on the company selected on the Incident form. I have created a script include to do this bit :
var getCurrentCompanyUsers = Class.create();
getCurrentCompanyUsers.prototype = {
      initialize: function() {
  var userslist = '';
  var comp = current.company;
  var usr = new GlideRecord('sys_user');
  usr.addQuery('company',comp.sys_id);
  usr.query();
  while(usr.next()) {
  if(userslist.length > 0) {
  userslist += (',' +usr.sys_id);
  else {
  userslist = usr.sys_id;
  return 'sys_idIN' +userslist;
      type: 'getCurrentCompanyUsers'
Still, it is showing the list of all the users in the system and not in the selected company. Is there something I am missing in the code ?
(I can use the dependent functionality but using the advanced ref qualifier so that the filter could be modified at any time)
Unfortunately Reference Qualifiers don't show the query in the breadcrumb.
I posted some code up on how to do it via UI Macro and Field decorators a little while ago.
See my comment on the thread below:
Reference Lookup Initial Filter
I will try adapt it for you below:
Use a UI Macro
http://wiki.servicenow.com/index.php?title=UI_Macros#gsc.tab=0
Then, use the ref_contributions attribute to call it on the field.
Dictionary Attributes - ServiceNow Wiki
<j:set var="jvar_n" value="my_company_users_${ref}"/>
<g:reference_decoration id="${jvar_n}" field="${ref}"
  onclick="filterUserByCompany(); "
  title="${gs.getMessage('My Companies Users')}" image="images/icons/tasks.gifx"/>
<script>
  function filterUserByCompany() {
  var thefield = 'caller_id'; //Identify the reference field this should be attached to.
  var thetable = 'incident'; //This gets whatever table you are on.
  var lookupfield = 'lookup.'+ thetable + '.' + thefield; //Creates the lookup or reference field ID.
  var thetarget = thetable + '.' + thefield;
  var url = "&amp;amp;sysparm_query=company=" + g_form.getValue('company');
  var refurl = reflistOpenUrl(thetarget, thetarget, thefield, 'sys_user', 'null', 'false', '');
  var refurlquery = refurl + url;
  popupOpenStandard(refurlquery, 'lookup');
</script>
</j:jelly>
33 REPLIES 33
Thanks mate, any chance the company value also could be updated to the new value when the caller gets updated ?
jennykin
Giga Contributor
Hello Paul / Suhas, any chance you guys have been able to populate the new company value in the company field ? Even I seem to be stuck at the same place
Sorry, can you please explain what you are trying to do in more detail?
When I select the another user from a different company, like ACME Australia here for ex., the company field doesn't change to ACME Australia. (Allie P is from ACME Australia & I am using my dev instance here)
I wrote an On change client script on 'caller_id' field and this seems to work now.
g_form.setValue('company', caller.company);
Is there any potential pitfalls of using this ?
