Advanced reference qualifier not working in ServiceNow Workspace
shrikant Kahar1
Advanced Reference qualifier not working in ServiceNow workspace. As same functionality working as expected in Classical UI.
I tried with the attribute "ref_qual_elements" but it's not working in workspace
Thank in advance
Shrikant
15 REPLIES 15
Ankur Bawiskar
@shrikant Kahar1
if your cmn_department field is present in workspace view in form then your logic should work fine.
Please ensure that
ny5_6
I am facing the same issue, I believe this is a workspace bug. I have a list collector field, and when I look up a record for it the first time, it works fine. But then if I clear the value and do another lookup (within the Workspace) it comes back empty. Everything works as expected in the back-end UI, this is 100% a workspace issue. I am thinking of opening a Case, would advise the same.
Hi @ny5_6 ,
Were you able to resolve this?
Unfortunately not. We were working with a customer at the time and I am not sure they ever opened a case.
Shaida Aslam
Hi @shrikant Kahar1 ,
We are facing the same issue with OOB reference qualifier on Department field on Project. Works fine in Classic UI but doesn't filter in the Workspace 'Create New Project' Modal. Were you able to figure this out?
