After BR is not running
VanamaA
Hi Everyone,
I have created a simple After insert,update BR on SG-Intune Computer Related table,where it shows a Infomessage message.But that BR is not running.
Can anyone help me on this
Thanks in Advanced
12 REPLIES 12
Sanjay Bagri1
Please share the screenshots of your BR and actual scenarios so folks can understand your query.
Ravi Chandra_K
Check if there are any setWorkflow(false) method used on the same Table...
If the info message within BR is displaying, then the BR is running...
are field actions within BR not working...?
Please mark the answer as helpful and correct if helped.
Kind Regards,
Ravi Chandra
Ravi Chandra_K
In which scope SG-Intune Computer Related table is present?
If it is different scope, you can try checking cross scope access policy for that Table...
Kind Regards,
Ravi Chandra
