All flows in queued state in flow engine context!
elle
Hello, everyone
My problem is that every flow is not automatically triggered in my personal instance, but they are all in queued state. But when I test them from flow designer they all work.
Muralidharan BS
Check in your sys_trigger, there should be a job called - Flow Engine Event Handler. If this is stuck try to nudge it. Also check event queue [sysevent] for backlogs.
15 REPLIES 15
Open the events process job, and update the time manually to next minute like below. And system id to all nodes
Thank you so much for the help!
You've welcome
I am also facing this problem, executions are queued in flow designer. In sys_trigger Flow Engine Event Handler the state is in running and system Id already assigned to our nodes present. Should i change the system ID to active nodes option and update the time? or if it's already assigned to a node and has state as running it is executing right?
mikewendel
Hello All,
I'm also struggling with Flows being queued and all what I read here and in other postings has not helped at all.
Are there more ideas how to start these flows, or to "restart" the whole Flow event/trigger thing???
It worked on Tuesday as espected and suddenly stopped on Wednesday without any reason, at least not a reason we can think of...
Best Regards
Michael
