All flows in queued state in flow engine context!
elle
Hello, everyone
My problem is that every flow is not automatically triggered in my personal instance, but they are all in queued state. But when I test them from flow designer they all work.
Muralidharan BS
Check in your sys_trigger, there should be a job called - Flow Engine Event Handler. If this is stuck try to nudge it. Also check event queue [sysevent] for backlogs.
15 REPLIES 15
Okay, thanks anyway!
I'm preparing a Show Case on a Demo Instance. Will see if a HI case will work.
