App Engine Studio Flow Inbound Email Trigger not working when flow is active
calin-borbeli
Hello ServiceNow experts,
As the title says I have an AES Flow Inbound Email Trigger that is not working when the flow is active.
I have looked through the forum at other similar issues but I couldn't find a solution.
The trigger and the flow works fine when tested but it doesn't trigger when the email comes in the inbox.
Here's the trigger with a couple of simple conditions:
I have also created an Inbound Email Action in Studio and that works perfectly fine using the same simple conditions.
This is obviously a workable solution, but I am questioning why the AES Flow Inbound Email Trigger is not working as expected or am I missing something?
Thanks in advance for your help.
Calin
Hi @calin-borbeli
May be you can reach out to your account rep to get the access.
Hi @calin-borbeli
Hi @Dr Atul G- LNG
I am just learning by myself so I don't have an account rep but you have been definitely helpful and I will accept your response as a solution.
Cheers,
Calin
