ATF: Set Component Values (Custom UI) filled data flashes and disappears
Wei_ Ling
Hello everybody:
When I want to use Set Component Values (Custom UI) in ATF to capture field fill data, the runtime finds that the values can be set, but then they disappear and the result is 0. What's the reason? Do any of you know?
My Settings are like this:
2 ACCEPTED SOLUTIONS
@Wei_ Ling
then create individual set component value step for each input and for every step give some timeout of 5 seconds etc
@Wei_ Ling,
in Step, you can find a field that can timeout set for 5 sec.
Below screen-shot refer.
Hemant
11 REPLIES 11
I can't find a place where I can set the waiting time. Could you give me some advice?
@Wei_ Ling
you possibly won't find it on form.
try to set the timeout from the list of the test steps
But what I need is to Set one of the Values in the Set Component Values (Custom UI) step and then wait and set the other values. It doesn't seem to work if I set them in the middle of the test step.
@Wei_ Ling
Ok, thank you very much. Can I set the time only by running server script? There doesn't seem to be a specific procedure for establishing wait times.
