Auto-Assignment Help!!
sanyalshubh
A user submits a request in Service Portal, and based on their role, the task needs to be automatically assigned to a specific user. For example, if the user has the "HR" role, the task should go to the HR team member.
3 ACCEPTED SOLUTIONS
Sandeep Rajput
@sanyalshubh There are multiple ways to achieve this implementation.
1. Business rule: create an onAfter insert business rule on the hr task table and check the user's role and assign the task to appropriate group
2. Flow: Create a flow which triggers on the task creation, check the requestor's role and assign's the task to appropriate group
3. Assignment rule: Check the requestor role in assignment role script and assign the task
4. Catalog OnSubmit client script: Check the user role in the catalog client script and assign the task.
Hope this helps.
Ravi Gaurav
So I am assuming @sanyalshubh if its a record producer.. then you can write a RP script..
current.assigned_to='SYSID of Assignment Group"
or Using Business Rule :-
if (userRoles.indexOf('hr') > -1)
current.assigned_to = 'sys_id_of_HR_user';
you can use the above logic.. Let me know if that helped you..
Hi @sanyalshubh
It is either, the question is why role based ? Let say you created a record via catalog item, and you have 70 roles assigned, now on which basis system will pick the assignemnt.
Ravi Chandra_K
Hello @sanyalshubh
You can try HR Skill management for this requirement.
https://www.servicenow.com/docs/bundle/xanadu-employee-service-management/page/product/human-resourc...
Please mark the answer as helpful and correct if helped.
Kind Regards,
Ravi Chandra
