Auto populate reference field based on other reference field
rickw1
Giga Contributor
Hi there,
I'm figuring out the best way to do this..
In my form, I have 2 fields: caller and hospital.
Caller refers to the users table, Hospital refers to the company table.
My goal is: whenever I populate the caller field, the system needs to lookup the hospital of that caller and needs to auto-populate that.
Example: Customer X is part of Hospital X. Customer X is the caller so will be populated in the caller field. The system recognizes that Customer X is part of Hospital X so hospital will be Hospital X.
Hope you guys can help me out!
rickw1
Giga Contributor
We got it working!
Client script:
    var ga = new GlideAjax('GetCustomerData');
  ga.addParam('sysparm_name','getFieldValue');
  ga.addParam('sysparm_field','u_reference_1');
  ga.addParam('sysparm_user_id', g_form.getValue('caller'));
      ga.getXML(DoSomething);
      function DoSomething(response) {
            var company = response.responseXML.documentElement.getAttribute("answer");
            g_form.setValue('company',company);
Script include:
var GetCustomerData = Class.create();
GetCustomerData.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
    getFieldValue: function() {
              var user = new GlideRecord('x_medt2_ihs_customers');
              user.get(this.getParameter('sysparm_user_id'));
              if(! user.sys_id){
                                return false;
        return user[this.getParameter('sysparm_field')];
Thanks everybody for the great help on this!
58 REPLIES 58
Daryll Conway
Giga Guru
You can create an on change client script on the Caller field something like this...
    var gr = new GlideRecord(<your_hospital_table>);
    gr.addQuery(<matching_field>, newValue);
    if(gr.next()){
  g_form.setValue(<your_hospital_field_on_the_form>, gr.sys_id);
Thanks everybody for the great help so far!
So what I'm reading is that a Business Rule or Client Script will do the job.
What would be the main difference between those two?
If a record would be created by the inbound email script instead of manual creation, would both solutions work too?
A client script will make the change on the form as you go where as a business rule will update upon save / submission
Also a client script is less efficient you may notice more of a lag when using client side lookups as it'll have to query the server.
A business rule will do all this on the server so load times will be quicker.
Really depends how big the tables are and whether you want live updates for the user.
If the record will be created through inbound email script, better go with BR.
