Auto populate reference field based on other reference field
rickw1
Giga Contributor
Hi there,
I'm figuring out the best way to do this..
In my form, I have 2 fields: caller and hospital.
Caller refers to the users table, Hospital refers to the company table.
My goal is: whenever I populate the caller field, the system needs to lookup the hospital of that caller and needs to auto-populate that.
Example: Customer X is part of Hospital X. Customer X is the caller so will be populated in the caller field. The system recognizes that Customer X is part of Hospital X so hospital will be Hospital X.
Hope you guys can help me out!
rickw1
Giga Contributor
We got it working!
Client script:
    var ga = new GlideAjax('GetCustomerData');
  ga.addParam('sysparm_name','getFieldValue');
  ga.addParam('sysparm_field','u_reference_1');
  ga.addParam('sysparm_user_id', g_form.getValue('caller'));
      ga.getXML(DoSomething);
      function DoSomething(response) {
            var company = response.responseXML.documentElement.getAttribute("answer");
            g_form.setValue('company',company);
Script include:
var GetCustomerData = Class.create();
GetCustomerData.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
    getFieldValue: function() {
              var user = new GlideRecord('x_medt2_ihs_customers');
              user.get(this.getParameter('sysparm_user_id'));
              if(! user.sys_id){
                                return false;
        return user[this.getParameter('sysparm_field')];
Thanks everybody for the great help on this!
58 REPLIES 58
also you need to change the caller to caller_id on the g_form.setValue
so g_form.setValue('company', caller.u_reference_1)
should be g_form.setValue('company', caller_id.u_reference_1)
    var caller_id = g_form.getReference('caller', setHospital);
function setHospital(caller_id)
  g_form.setValue('u_hosptial', caller_id.u_reference_1);
Doesn't work. Nothing happens.
(Sorry, still new on scripting)
Try this...
    var gr = new GlideRecord(<your_caller_table>);
    gr.addQuery('caller', newValue);
    if(gr.next()){
  g_form.setValue('company', gr.u_reference_1);
I get this error: onChange script error: ReferenceError: x_medt2_ihs_customers is not defined function (){var o=i(m,arguments);return l.apply(n,o)}
Hi community!
To populate that field when you are filling the form, you will need a client script on change. This would be the code:
    var caller = g_form.getReference('caller_id', getHospital); // getHospital is our callback function
function getHospital(caller) { //reference is passed into callback as first arguments
  g_form.setValue('company',caller.u_hospital) //Im guessing that the column name of the field Hospital on Customer form is u_hopital. Check the dicctionary to be sure!
I hope it helps!
Antonio.
