Auto populate reference field based on other reference field
rickw1
Giga Contributor
Hi there,
I'm figuring out the best way to do this..
In my form, I have 2 fields: caller and hospital.
Caller refers to the users table, Hospital refers to the company table.
My goal is: whenever I populate the caller field, the system needs to lookup the hospital of that caller and needs to auto-populate that.
Example: Customer X is part of Hospital X. Customer X is the caller so will be populated in the caller field. The system recognizes that Customer X is part of Hospital X so hospital will be Hospital X.
Hope you guys can help me out!
rickw1
Giga Contributor
We got it working!
Client script:
    var ga = new GlideAjax('GetCustomerData');
  ga.addParam('sysparm_name','getFieldValue');
  ga.addParam('sysparm_field','u_reference_1');
  ga.addParam('sysparm_user_id', g_form.getValue('caller'));
      ga.getXML(DoSomething);
      function DoSomething(response) {
            var company = response.responseXML.documentElement.getAttribute("answer");
            g_form.setValue('company',company);
Script include:
var GetCustomerData = Class.create();
GetCustomerData.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
    getFieldValue: function() {
              var user = new GlideRecord('x_medt2_ihs_customers');
              user.get(this.getParameter('sysparm_user_id'));
              if(! user.sys_id){
                                return false;
        return user[this.getParameter('sysparm_field')];
Thanks everybody for the great help on this!
58 REPLIES 58
Antonio Vegue Martinpintado wrote:
Ok! Look, you can do this as a temporary workaround at the moment:
  var gr = new GlideRecord('x_medt2_ihs_customers');
  if(gr.get(newValue))
          g_form.setValue('company',gr.u_reference_1);
  else
        alert('User is not a customer and does not have Hospital assigned');
The best solution for a good performance is, as Paul Morris and Pradeep Sharma said, create and Ajax script and call it from the client script. Check this link out http://wiki.servicenow.com/index.php?title=Client_Script_Best_Practices#Example:_Asynchronous_GlideA...
Did it work?
Unfortunately getting this error:
onChange script error: TypeError: GlideRecord is not a function function (){var o=i(m,arguments);return l.apply(n,o)}
It's still interesting that the BR is able to get the info very easily, but the CS doesn't.
Umm strange, I used that script on my dev instance (changing table and field to set) and it works perfectly. Could you send us an screenshot of the cliend script that you defined please?
Hi Rick,
Are you creating this as part of scoped application. Please confirm.
Pradeep Sharma wrote:
Hi Rick,
Correct Pradeep
