Auto populate reference field based on other reference field
rickw1
Giga Contributor
Hi there,
I'm figuring out the best way to do this..
In my form, I have 2 fields: caller and hospital.
Caller refers to the users table, Hospital refers to the company table.
My goal is: whenever I populate the caller field, the system needs to lookup the hospital of that caller and needs to auto-populate that.
Example: Customer X is part of Hospital X. Customer X is the caller so will be populated in the caller field. The system recognizes that Customer X is part of Hospital X so hospital will be Hospital X.
Hope you guys can help me out!
rickw1
Giga Contributor
We got it working!
Client script:
    var ga = new GlideAjax('GetCustomerData');
  ga.addParam('sysparm_name','getFieldValue');
  ga.addParam('sysparm_field','u_reference_1');
  ga.addParam('sysparm_user_id', g_form.getValue('caller'));
      ga.getXML(DoSomething);
      function DoSomething(response) {
            var company = response.responseXML.documentElement.getAttribute("answer");
            g_form.setValue('company',company);
Script include:
var GetCustomerData = Class.create();
GetCustomerData.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
    getFieldValue: function() {
              var user = new GlideRecord('x_medt2_ihs_customers');
              user.get(this.getParameter('sysparm_user_id'));
              if(! user.sys_id){
                                return false;
        return user[this.getParameter('sysparm_field')];
Thanks everybody for the great help on this!
58 REPLIES 58
Hi Rick,
Glide record is not supported / allowed in client side scripts in scoped apps. You have to use GlideAjax to fulfill the requirement.
You can refer the below thread for more info.
Error using GlideRecord in a scoped application in Fuji
Ok so I guess that this error is because GlideRecord is not supported / allowed in client side scripts in scoped app. So we will have to do the AJAX call solution.
So the code you should do is something like this:
  • 1. On change client script:
      ga.addParam('sysparm_user_id',newValue);
  • 2. Create a Script include, must be client callable and the name should be GetCustomerData [It should match the name used on GlideAjax constructor].
GetCustomerData.prototype = Object.extendsObject(AbstractAjaxProcessor, {
              if(! user.sys_id){
                                return false;
You can use GetCustomerData to get any data from the customer record, the only thing you should do is change the column on ga.addParam();
Only creating the CS and SI gives me this error:
AbstractAjaxProcessor undefined, maybe missing global qualifier
Antonio Vegue Martinpintado wrote:
[...] the only thing you should do is change the column on ga.addParam();
I assume you mean these?
What exactly needs to be changed there? And to which colomn?
Sorry I mixed up a couple of thigs. On the client script you should use:
I hope this finally works
