Business Rule: Create Problem when an incident has 5 child incidents
Brendan Hallida
Hi all,
I have a requirement to create a problem record when an incident has 5 child incidents.
I was thinking of using glide aggregate to perform the count, and use the fact that when the 5th child has the parent added, the comments are updated in the parent and then will run the BR.
Here is the script that I have, it is not working correctly.  I feel I am close.
When to Run: Before on Insert and Update
Script:a
//Find all child incidents for current incident
var childInc = new GlideAggregate('incident');
childInc.addQuery('parent' , current);
childInc.addQuery('active' , 'true');
childInc.addAggregate('count');
childInc.query();
while(childInc.next()){
gs.log('The number of child incidents for ' + current.number + ' is: ' + childInc.getAggregate('count'));
if(childInc.getAggregate('count') >=5) {
gs.log('>=5 worked');
    // Create the problem
	var problem = new GlideRecord('problem');
	problem.short_description = current.short_description;
	problem.description = current.description;
	problem.cmdb_ci = current.cmdb_ci;
	problem.priority = current.priority;
	problem.assignment_group = current.assignment_group;
	problem.assigned_to = current.assigned_to;
	problem.category = current.category;
	problem.subcategory = current.subcategory;
	problem.impact = current.impact;
	problem.urgency = current.urgency;
	problem.business_service = current.business_service;
	problem.first_reported_by_task = current.sys_id;
	problem.insert();
	gs.log('Problem Number is: ' + problem.number);
	// Link the problem to this incident
	current.problem_id = problem.sys_id;
	current.setWorkflow(false);
    current.work_notes = 'A problem: ' + problem.number + ' has been created as this incident contains more than 5 child incidents.';
	current.update();
else{
gs.log('>=5 failed');
})(current, previous);
Does anyone have any ideas?  the problem creation part I'm not to fussed with and probably needs refining, I cannot get the logic to work.
Cheers, Brendan
12 REPLIES 12
Mark Roethof
Hi there,
You could simplify your code. The GlideAggregate doesn't need a while for example. The addQuery for active, use true without quotes (it's a boolean) or use addActiveQuery.
The actual problem creation, the comment from Abhisnek is very useful.
Question:
When does this BR run. I mean, this occurs if a 5th Incident is created. Though where is your logic from preventing this to run if a 6th or 7th incident is created? Guess you don't want new problems each time this happens?
Kind regards,
Mark
LinkedIn
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
Cheers mark, will look into simplifying the code 🙂
Good call out with the extra child incidents, I was planning on using a condition around ignoring if the incidents problem_id is not empty
Goran WitchDoc
Hi Brendan,
I would have a different approach here. First I would use a flow, so you don't need to write any code at all =). Then there is actually already a counter on incidents that shows how many child incidents it has. It's called "child incidents".
So you can bascially just have a trigger saying that when that field is 5 or higher and doesn't have a value in the problem field, run this. If it's a flow, you can even make it as a run once, so it won't even check the trigger later on.
Then if it's triggered, you just need to create the problem and update the problem field on the incident.
How does that sound?
//Göran
Feel free to connect:
LinkedIn
Subscribe to my YouTube Channel
or look at my Book: The Witch Doctor’s Guide To ServiceNow
Hi Göran,
Sweet, I will take a look.  I did notice that the child.incidents field is not filling in my development instance.
Mark Roethof
Other thing I noticed:
Are all problem fields correct? You are using for example problem.first_reported_by_task. I don't see this out-of-the-box? Should this be a u_ field?
Kind regards,
Mark
LinkedIn
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
