Business rule help required on Catalog task Active field
Lucky1
Hello all,
I have modified an already existing BR and the BR is giving info Messages what I have written but not changing the Active field value to false. Please help me.
Lucky
Sandeep Rajput
@Lucky1 try the following and see if it works
task_rec1.active=false; //false without quotes
task_rec1.update();
Ankur Bawiskar
@Lucky1
active field is boolean so you should set it with true or false and not as string
