Capacity in use - recalculation for agents using advanced work assignment not working
Edxavier Robert
Hi, I am currently in the implementation of the Advanced  Work Assignment for the sc_task, but the Capacity in use is not refreshing the counting after tasks are closed causing that Tech don't receive a new task.
Table: awa_agent_presence_capacity_list
Field: ac_workload
There's a Client Script (OOB) that run
	if (newValue < 0)
		g_form.showErrorBox('max_capacity', getMessage('Capacity must be greater than or equal to 0'));
Edxavier Robert
Hi @Sherman Ignacio,
Yes, I find the root of cause of the issue. There is a scheduled job called "Re-register AWA Record Watcher" which automatically re-create missing record watcher responders. It is active OOB and in my case it was set to false.
Make sure is set to true.
Let me know if this works for you.
Edxavier Roberto
15 REPLIES 15
Soukaina
The job is already active in my case but I still have the same issue. Did anyone find a solution to make the capacity in use change when an incident is resolved ?
SY
Same here. Job is active but the Capacity in Used is still not updating. Have you find a solution ? Based on my setup in Service Channel, Utilization condition is set set to State is oneOf (New,In Progress, On Hold) but after I resolved the ticket , Capacity in Used is not updating.
Yue
Hi Sy,
Have you find a solution for this?
Kyu
rameshraman
Was this issue resolved? Can you pls share the resolution.
Soukaina
Yes I did. I added the same condition as @Sherman Ignacio and it works for me.
BR,
SY
