Capacity in use - recalculation for agents using advanced work assignment not working
Edxavier Robert
Hi, I am currently in the implementation of the Advanced  Work Assignment for the sc_task, but the Capacity in use is not refreshing the counting after tasks are closed causing that Tech don't receive a new task.
Table: awa_agent_presence_capacity_list
Field: ac_workload
There's a Client Script (OOB) that run
	if (newValue < 0)
		g_form.showErrorBox('max_capacity', getMessage('Capacity must be greater than or equal to 0'));
Edxavier Robert
Hi @Sherman Ignacio,
Yes, I find the root of cause of the issue. There is a scheduled job called "Re-register AWA Record Watcher" which automatically re-create missing record watcher responders. It is active OOB and in my case it was set to false.
Make sure is set to true.
Let me know if this works for you.
Edxavier Roberto
15 REPLIES 15
What was the condition ?
thanx in advance
karan21
This is a known error with ServiceNow.
If you are using 'Add Or Condition' in Service Channel anywhere, it would not free up the capacity.
We re-configured our service channels to not have 'Add or Condition'
PS: you can have regular 'Or' condition.
They did create a Problem ticket for this but no updates yet 😕
PRB1497434
Joel A_1
Giga Expert
On my end the job is active and we do not have 'Add or Condition' in use but with some agents we also have this issue. Any ideas?
Can you share more about the use case, in what situations does the agent capacity not reset?
Hi kgag,
Out of about 50 agents working at the same time, only 2-3 agents have this at a time. But I have no idea exactly in which use case. At first I suspected this for agents who had time outs or rejected Work Items. However, the problem also exists with agents who have never worked with AWA before or are new and therefore have never had a time out or rejected a case. Unfortunately, it is really completely unclear to me why.
