Capacity in use - recalculation for agents using advanced work assignment not working
Edxavier Robert
Hi, I am currently in the implementation of the Advanced  Work Assignment for the sc_task, but the Capacity in use is not refreshing the counting after tasks are closed causing that Tech don't receive a new task.
Table: awa_agent_presence_capacity_list
Field: ac_workload
There's a Client Script (OOB) that run
	if (newValue < 0)
		g_form.showErrorBox('max_capacity', getMessage('Capacity must be greater than or equal to 0'));
Edxavier Robert
Hi @Sherman Ignacio,
Yes, I find the root of cause of the issue. There is a scheduled job called "Re-register AWA Record Watcher" which automatically re-create missing record watcher responders. It is active OOB and in my case it was set to false.
Make sure is set to true.
Let me know if this works for you.
Edxavier Roberto
15 REPLIES 15
Mark Anderson2
Adding to the thread as I am experiencing the same condition and the stated scheduled job is active and running in our environment.
