Catalog client script help
Thomas98
Can someone please help me with the catalog client script?
I have two field
1) select_the_type_of_access_required
2)  u_description
I need an on change catalog item script
when I select the "type of access" the description should auto fill itself.
Custom table name " u_Azure_role
I have something in place but it wont work 😞
   if (isLoading) {
   }var user = g_form.getReference('select_the_type_of_access_requireds', populateDetails);
function populateDetails(user) {
    g_form.setValue('description',u_azure_roles.u_description);
3 ACCEPTED SOLUTIONS
Harsh_Deep
Hello @Thomas98 ,
Is select_the_type_of_access_requireds a reference field?
If so, replace
with
g_form.setValue('description',user.u_description);
Harsh_Deep
Hello @Thomas98
You have to use Script Include Call using client script-
https://www.servicenow.com/community/developer-articles/how-to-call-script-include-from-client-scrip...
Please open the above link and complete your requirement.
Please mark correct answer and helpful for others if it helps you
Hello @Thomas98
In line number 7th you are passing role but you haven't defined role anywhere.
17 REPLIES 17
AshishKM
user the user object in place of custom table name because you are taking that object as input parameter in populateDetails function.
g_form.setValue('description', user.u_description);
Harish KM
Hello @Thomas98 if your Servicenow is on Utah version and above you don't need client script to achieve this. You can use autoPopulate feature, check example below
https://www.servicenow.com/community/developer-articles/auto-populate-reference-data-in-service-cata...
Harish
Hi Harish, Yes, it will help. However, it will still be applicable only for Reference not for Lookup Select box.
I tot it's a reference field.
Harish
Ankur Bawiskar
@Thomas98
getReference I believe won't work with lookup select box
Please use GlideAjax
