Catalog client script help
Thomas98
Can someone please help me with the catalog client script?
I have two field
1) select_the_type_of_access_required
2)  u_description
I need an on change catalog item script
when I select the "type of access" the description should auto fill itself.
Custom table name " u_Azure_role
I have something in place but it wont work 😞
   if (isLoading) {
   }var user = g_form.getReference('select_the_type_of_access_requireds', populateDetails);
function populateDetails(user) {
    g_form.setValue('description',u_azure_roles.u_description);
3 ACCEPTED SOLUTIONS
Harsh_Deep
Hello @Thomas98 ,
Is select_the_type_of_access_requireds a reference field?
If so, replace
with
g_form.setValue('description',user.u_description);
Harsh_Deep
Hello @Thomas98
You have to use Script Include Call using client script-
https://www.servicenow.com/community/developer-articles/how-to-call-script-include-from-client-scrip...
Please open the above link and complete your requirement.
Please mark correct answer and helpful for others if it helps you
Hello @Thomas98
In line number 7th you are passing role but you haven't defined role anywhere.
17 REPLIES 17
Harsh_Deep
Hello @Thomas98
Alka_Chaudhary
Hello @Thomas98 ,
For lookup select box, you have to use GlideAjax to call the script include and get the value.
You can create catalog client script using the below code:-
    var ga = new GlideAjax('getLookupDescription');
    ga.addParam('sysparm_name', 'getDescription');
    ga.addParam('sysparm_number', newValue); //newValue will look up field for
    ga.getXML(callback);
    function callback(response) {
        g_form.setValue('description', answer);
Also, create script include with name 'getLookupDescription' and check the client callable check box.
and write the below script and according to the comment of line 6,7 & 10 replace the required data:-
var getLookupDescription = Class.create();
getLookupDescription.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    getDescription: function() {
        var num = this.getParameter('sysparm_number');
        var gr = new GlideRecord("incident"); //replace the table name with the table that you selected in lookup variable
        gr.addQuery("number", num); // replace 'number' with the field backend name that you have selected in lookup variable
        if (gr.next()) {
            return gr.description.toString(); //replace description with the backend name of the description field of the table that you selected in lookup variable
    type: 'getLookupDescription'
 for reference:-
If this response clears up your doubt, kindly flag it as both helpful and correct.
Alka
Thank you Alka for taking the time.
I still couldn't get it working 😞 could you please validate my code:
Script Include:
        var gr = new GlideRecord("u_azure_roles"); //replace the table name with the table that you selected in lookup variable
        gr.addQuery("u_role", role); // replace 'number' with the field backend name that you have selected in lookup variable
        if (gr.next()) {
            return gr.u_description.toString(); //replace description with the backend name of the description field of the table that you selected in lookup variable
Catalog client script:
variable:
Azure table fields:
u_role
u_description
@Thomas98 , what is the variable name of description where you want to display description from table?
@Thomas98 Also, did you make the script include client callable and with the name 'getLookupDescription'? Send me the screenshots.
