Checkbox Problem in Catalog Client Script
jeansky
Hello, I would like to ask why the select boxes don't show when I select the checkboxes. I don't know if this is possible in catalog client script. Any suggestion is appreciated. Thank you.
Here's my script:
    g_form.setDisplay('checkbox1', false);
    g_form.setDisplay('checkbox2', false);
    g_form.setDisplay('checkbox3', false);
    g_form.setDisplay('selectbox1', false);
    g_form.setDisplay('selectbox2', false);
    g_form.setDisplay('selectbox3', false);
    var request_type = g_form.getValue('request_type');
    if (request_type == 'Account Creation') {
            g_form.setDisplay('checkbox1', true);
            g_form.setDisplay('checkbox2', true);
            g_form.setDisplay('checkbox3', true);
            var checkbox1 = g_form.getValue('checkbox1');
            var checkbox2 = g_form.getValue('checkbox2');
            var checkbox3 = g_form.getValue('checkbox2');
            if (checkbox1 == true) {
                g_form.setDisplay('selectbox1', true);
            else if (checkbox2 == true) {
                g_form.setDisplay('selectbox2', true);
            else if (checkbox3 == true) {
                g_form.setDisplay('selectbox3', true);
            else {
    else if (request_type == 'Delete Account') {
Based on my understanding of your code, I would suggest that within your new onChange client scripts on each Checkbox, you can have a condition like -
if(g_form.getValue('checkbox1')==true && g_form.getValue('request_type')=='Account Creation')
//show the select-box part
This way whenever RequestType if 'Delete Account' & even if CheckBox1 is true, you won't be showing SelectBoxes. Same logic you can put in all the other onChange client scripts as well.
Do mark this response as CORRECT / HELPFUL if you find it appropriate.
jeansky
Thanks a lot. It worked. 😊
My First Accepted Solution - Thanks @jeansky 😀
H S B
Giga Guru
My understanding is, you need to write a different onChange client script on each CheckBox1/2/3 if you want to show another field whenever these are checked / unchecked.
Currently you are trying to show everything onChange of 'Request_Type' field.
For more details, can you please explain, on which variable change, you want to show the selectBox variables?
Do mark this answer as HELPFUL / CORRECT if it helps.
Sandeep Rajput
@jeansky As suggested by Elijah, you would need to define onChange scripts for your check boxes too. However, I recommend you to create UI Policies instead to hide/show the select boxes.
