Client script and script include suddenly not working
Ramsha Shaikh
Hi i have this script include that when the drop down is modify or remove all it shows the groups user is part of in a servicenow group field (i.e a list collector) but for some reason the value is not setting in the field anymore and it isn't showing all the groups the requested for is part of this was working perfectly till yesterday but suddenly it stopped working can someone please help me out with this
this is my script include
var getAssignmentGroupofMember = Class.create();
getAssignmentGroupofMember.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    getAssignmentGroup: function() {
        var getUser = this.getParameter("sysparm_requestedForValue");
        var getType = this.getParameter("sysparm_type_is");
        gs.log('11-12-23 type is ' + getType);
        gs.log("11-12-23 sys_id: " + getUser);
        if (getType == 'remove_all') {
			var grm = new GlideRecord('sys_user_grmember');
            grm.addQuery('user', getUser);
            grm.query();
            var grpArray = [];
            while (grm.next()) {
                grpArray.push(grm.getDisplayValue("group"));
                gs.log("member group array 812" + grpArray+'user is'+getUser);
            return grpArray.toString();
            // gs.print(grpArray);
            // gs.print(grpArray[0]);
        } else if (getType == 'modify') {
            var grp1Array = [];
            var grm1 = new GlideRecord('sys_user_grmember');
            grm1.addQuery('user', getUser);
            grm1.query();
            while (grm1.next()) {
                grp1Array.push(grm1.getDisplayValue("group"));
                gs.log('groups not in ' + grp1Array+'user is'+getUser);
            //var a = grp1Array.toString();
            return  grp1Array.toString();
        } //else if(getType == 'add') {
            // var grm2 = new GlideRecord('sys_user_grmember');
            // grm2.addQuery('user', getUser);
            // grm2.query();
            // var grp2Array =[];
            // while (grp2.next()) {
            //     grp2Array.push(grm2.getDisplayValue("group"));
            //     gs.log('groups in' + grp2Array);
            // return  grp2Array.toString();
    type: 'getAssignmentGroupofMember'
 and this is my client script
    var g_form_item = g_form;
    var requestedforValue = g_form_item.getValue('requested_for');
    var type_is = g_form.getValue('request_type');
    if ((type_is == 'modify') || (type_is == 'remove_all')) {
        alert('User will be removed from the groups selected in ServiceNow groups after the group manager approval');
    var ga = new GlideAjax('getAssignmentGroupofMember');
    ga.addParam('sysparm_name', 'getAssignmentGroup');
    ga.addParam('sysparm_requestedForValue', requestedforValue);
    ga.addParam('sysparm_type_is', type_is);
    ga.getXML(setAssignmentGroup);
    function setAssignmentGroup(response) {
        if (answer) {
            //var pa=JSON.parse(answer);
            alert(answer);
            //g_form.clearValue('servicenow_groups');
            g_form.setValue('servicenow_groups',answer);
can someone please help out as it is urgent.
Maik Skoddow
Hi @Ramsha Shaikh
according to your Script Include you are returning display values from table sys_user_grmember:
But this is wrong, as list collector fields store Sys IDs.
Instead, use something like this:
grp1Array.push(grm1.getValue('group'));
Use this approach everywhere in your script and adopt the script code accordingly.
Maik
12 REPLIES 12
Hi @Ramsha Shaikh ,
In alert are we getting the values?
Also the service now groups field is of what type?
Danish
Ramsha Shaikh
Hi @Danish Bhairag2
Alert is getting the values and the servicenow field is a lost collector
I mean a list collector
Hi @Ramsha Shaikh ,
Can u try this & see if it works
 g_form.setValue('servicenow_groups',answer.join());
Danish
Hi @Danish Bhairag2
No it isn't working its not working its saying an Unhandled exception in GlideAjax. when I go to inspect the error
