Client script with get reference is not working in workspace
akshaygadew
I have written a client script for work space using get reference which is working as expected , but in classic UI it is not working. do we need to create new client script for classic ui ?
no Ui policy are conflicting. global check box is also check .
with out reference script is working in Classic Ui
with reference script is working in workspace
What should i do so that code will work for both classic ui and workspace ?
@akshaygadew
please use getReference() with callback and see if it works in workspace
If not then please use GlideAjax.
Can you send the code here?
Please give a try with the GlideAjax.
