Client side script and Script include not working
NamitD
Hello ,
I am trying to set VIP checkbox as true if a user is vip in incident form via client script and script include , here is my code but its not working . I created new field on incident form to set it but its not working and not returning anything via alert as well. Any help ?
Client Script:
   var c = g_form.getValue('caller_id');
   var g = new GlideAjax('userV');
   g.addParam('sysparm_name','isVip');
   g.addParam('sysparm_value',c);
   g.getXMLAnswer(call);
   function call(response){
    var answer = response.responseXML.documentElement.getAttribute('answer');
    alert(answer);
    g_form.setValue('u_vip',answer);
Script Include:
var userV = Class.create();
userV.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    isVip : function(){
        var u = this.getParameter('sysparm_value');
        var sr= new GlideRecord(sys_user);
        sr.addQuery('sys_id',u);
        sr.query();
        if(sr.next()){
            var s = sr.vip;
            return s;
    type: 'userV'
Hi @NamitD ,
I have tried the below in PDI and it is working. Please check the below for reference:
Script Include(client callable - true)
    isVip: function() {
        var userID = this.getParameter('sysparm_value');
        var userTab = new GlideRecord('sys_user');
        if (userTab.get(userID)) {
            var checkVIP = userTab.vip;
        return checkVIP;
    type: 'userV'
Also, check if there are any ACL created when you are creating script include, like below. You need to evaluate true according to it otherwise it wont work, OR you can disable the ACL after elevating to 'security_admin'.
onChange Client Script:
    g.addParam('sysparm_name', 'isVip');
    g.addParam('sysparm_value', c);
    g.getXML(userVIPCheck);
    function userVIPCheck(response) {
        g_form.setValue('u_vip', answer);
Output:
Not a VIP User:
VIP User:
Mark this as Helpful / Accept the Solution if this helps
Mark this as Helpful / Accept the Solution if this helps.
NamitD
@Its_Azar @SN_Learn I tried these but its not reflecting on the form . Its not showing u_vip as true on the form .
Hi @NamitD ,
    isVip: function() {
        return checkVIP;
    type: 'userV'
Output:
Not a VIP User:
VIP User:
NamitD
Hi @SN_Learn ,
yes your solution did worked , I was using getXMLAnswer instead of getXML thats why it wasnt working.
