‎10-11-2020 06:31 AM
Hello guys,
At present I am using the Serial Number as Coalesce field in my Transform Map for Integration .
Now the problem is there are some CIs in my instance whose Serial Number is either empty or is using the different type of serial number as created by discovery which is Baseboard .And my data source is bringing the Bios Serial Number.
And hence due to these duplicates are being created.
To solve this I am thinking to write the script
As per that first priority for coalesce will be Serial Number .
But if it is empty or not matches I want to check the name of the Ci as 2nd option of coalesce .
How to achieve this ?
Can anyone help?
Regards ,
Mahak
Integrations
Scripting and Coding
- 9,335 Views
‎10-15-2020 08:00 PM
Hi Mahak,
if you have removed the coalesce then the action == 'update' won't work
also action == "insert" won't work
try to modify the code as suggested by me earlier
target object won't give you the target field value as you have removed the field map and coaslece
‎10-14-2020 09:13 PM
sample script below
var query = 'serial_number=' + source.u_bios_serialnumber + '^ORname=' + t + '^ORdns_domain=' + source.u_computer_domain_name;
var gr = new GlideRecord('ABC');
gr.addEncodedQuery(query);
if(gr.next())
// update existing record into target and ignore
gr.field1 = source.u_field1;
gr.field2 = source.u_field2;
gr.update();
ignore = true;
else
// insert new record into target and ignore
gr.initialize();
gr.insert();
‎10-15-2020 11:26 AM
Hello Ankur,
Thank you for the help.
I have written the onbefore script and remove the Coalesce from Serial Number .
But event after that its not checking the fqdn of cis as the 2nd priority and creating the duplicates even if the serial number is different but if fqdn is same it should not insert any new record.
Also it not copying the concatenated value in fqdn field after inserting.
(function runTransformScript(source, map, log, target /*undefined onStart*/ ) {
// Add your code here
if(action == "update" && source.u_bios_serialnumber == target.serial_number && target.discovery_source != "ABC")
ignore=true;
else if(action == "insert" && (source.u_operation_system == 'Windows Server 2008 Enterprise Edition')||(source.u_operation_system == 'Windows Server 2008 R2 Standard Edition')||(source.u_operation_system == 'Windows Server 2008 Standard Edition')||(source.u_operation_system == 'Windows Server 2012')||(source.u_operation_system == 'Windows Server 2012 Datacenter Edition'))
var t = source.u_computer_name.toString();
t = t.toUpperCase();
t = t.split('.')[0];
var bb = source.u_computer_domain_name.toString();
var aa = t +'.' + bb ;
var que = 'serial_number=' + source.u_bios_serialnumber + '^ORfqdn=' + aa;
gr.addEncodedQuery(que);
if(gr.next())
ignore = true;
else
var gg = new GlideRecord('ABC');
var cc = source.u_computer_name.toString();
cc = t.toUpperCase();
cc = cc.split('.')[0];
var dd = source.u_computer_domain_name.toString();
var ee = cc +'.' + dd ;
gg.initialize();
gg.disk_space = source.u_disk_total_space;
gg.dns_domain = source.u_computer_domain_name;
gg. ip_address = source.u_ip_addr1_text;
gg.mac_address = source.u_mac_addr1;
gg.name = t;
gr.fqdn = ee;
gg.insert();
else
ignore = true;
})(source, map, log, target);
Can you please help?
Mahak
Hi Mahak,
‎02-15-2023 09:50 PM
Hi @Ankur Bawiskar ,
Same issue i am also facing, if state is cancelled then it should ignore but instead of that its creating, I Just followed the same which you said but its still updating the record which is already existed CI record with in the cancelled state .
