Create Issue from Smart Assessment Engine using Automation tab
anandwakode
I want to create an Issue when my answer is no in Smart Assessment Engine using Automation tab. When I select the Automation tab in Action Type dropdown it shows me empty.
glideFather
Ahoy @anandwakode,
could you possibly add a screenshot to better understand your requirement/issue?
✂-----Cutting-out-the---✦AI-noise✦---All-replies-written-and-vouched-for-by-GlideFather---
Tanushree Maiti
Hi @anandwakode
It seems you are getting the issue because no Subflows have been properly defined and associated with the template category. Validate your steps as per following article.
Ref: ServiceNow Smart Assessment Simplified: A Step-by-Step Practical Guide!
https://www.servicenow.com/community/grc-forum/smart-assessment-engine-action-category/td-p/3388171
Tanushree Maiti
