Creation of assessment using flow designer
Prasad49
Hi Developers,
Need your help to overcome challenge am facing while configuring Action in Flow designer, am able to create the assessments instance but when i try to take the assessment the questions don't show up, trigger ID is also empty
Hi @Prasad49
In assessment question stage, the "Source table" field should be mapped to your custom table. I think you selected "assessment metric type".
Also, update "Due date" in stage 1 when you are creating assessment instance. Please correct these two steps and try.
jcmings
In your Create Assessment instance record flow action, I believe you'll need to input the table name (e.g. "sn_hr_core_case") into the field Trigger table. It looks like you're already putting the sys_id into Trigger ID (rather than a reference field), which is good. Here is a similar post where that was the solution.
Prasad49
after adding the trigger table, trigger ID is reflecting but the questionnaire is not reflecting
jcmings
I'm not super familiar with assessments. Are you certain that the users have access to see all of the questions? I'd check with the Debug Security Rules module and see if any ACLs are failing for your test user.
