Data archiving for Problem and its related records
prashu
We have a requirement to implement data archiving for problem and problem related records.
We have implemented the below functionality.
Problem:
I have created an archive rule and its archive related records for the following
Below are the archive related records which does not have the reference field so I used dot-walking for archiving the following related records.
  • PTASK Ticket
  • Related changes
  • Related CSI
->It works fine but need to confirm whether it is a best Practice or not? and also wanted to know from where the reference field choices comes from?
And below are the archive related records which already had a reference so I used the existing one.
  • Attachments
  • SLA's
Problem Subtask:
->We also need to archive the Problem subtask related records as well. Can we achieve it using the same archive rule or need to create a new archive   rule?
Any suggestions/ideas. Please guide me on this.
Thanks in advance,
Prashanthi
This is from wiki
  • The Archive action updates the Document ID of the related record to point to the archived table. For example, if you select the Table sys ID Attachment(sys_attachment)* reference, the related record rule updates the attachment record to change the Document ID to refer to the archived table record.
Attachment is not actually archived, but it shows up on the archived record same way as it was on the main record. Only the reference on the sys_attachment table gets updated. If this is not happening in your case automatically then contact HI.
Or you don't want the above scenario and you are trying to achieve something else?
nikhil_001
Hi Anurag,
If we increase the batch_size to 2000. How much impact can it have on the performance?
glide.db.archive.batch_sizeControls how many records an archive rule processes per batch job.Integer2000
glide.db.archive.sleep_timeControls how long each archive rule batch job runs, in seconds.Integer1
glide.db.archive.max_iterationsControls the maximum number of batch jobs to run within an hour.Integer10
Thanks & Regards,
Nikhil jain
