difference between * and none in acl
snow3
i have gone through the community links too but still i didnt get the difference between record level "none" and wildcard "*"
can anyone explain with the scenerio..
Pooja Mallikarj
Table.*  is a field level ACL which gives Access to all field on that table.
Table.none  is a row level ACL which allows you to access records.
Both are table level ACL, But the thing is * is a wild card entry. Suppose None is restricting table level access and you provide access by using * , system can allow you to do the work.
Examples:
If you define a READ ACL with:
•Table.None for Admin & ITIL
Result: Both Admin and ITIL will be able to view all records because they have read access to all records with no field restrictions.
•Table.None for Admin & ITIL & Table.* for Admin
Result: Only Admin will have read access because the Table.* is an explicit rule at the field level that grants only Admin read access to all fields.
•Table.None for Admin & Table.* for ITIL
Result: ITIL will not be able to view any records because they only have read access at the field level and not at the Record/Row level.
*.* represents = all records in all tables.all fields in a record
Please mark it as helpful/correct if it helps for you.
Pooja
Hey giga,
To be straightforward , the answer will be no , admin will have access because admin has read access at record level on the contrary the itil user has access for field level but lacks access to record level .
