Difference between Locked Out users and Inactive Users
devd1
I am very new for SNOW Tool. Could you please help me to get the difference between Locked Out users and Inactive Users. Thanks in Adv...
Chuck Tomasi
Hi Devendra,
Locked out means they cannot login but are in the system as a current user (e.g. existing employee who tried the wrong password too many times.)
Inactive means they are no longer with the organization (e.g. active=true is a handy way to filter out ex-employees.)
12 REPLIES 12
Hi vemffm,
Inactive users (active=false) are hidden in most cases via the platform UI; Please check the out-of-box business rule "user_query" which adds an active query condition to interactive sessions if the logged in user does not have the admin role. This before query rule will effectively hide inactive users from being selected in reference fields like incident caller or task assigned to.
Aric
Hi Aric,
the business rule is active ... nevertheless we can assign locked users to groups or open incidents for them ...
I checked in my developer instance and there it is the same ...
Hi vemffm,
The "user query" business rule will only affect users who are inactive. If you are looking to hide/filter locked out users, this is a separate attribute on the user record, thus would need additional logic to filter. You could make a copy of the existing "user query" business rule and update the script to add the additional query condition. Something like the following may accomplish this:
current.addQuery('locked_out', false);
** Please understand that the addition of a new before query business rule on sys_user may significantly impact out-of-box and custom applications. Please proceed with caution.
Aric
Hey Aric,
thnx for your help.
The issue was, that I did check with the admin account. And the business rule "user querey" explicitly checks if u are admin.
So all good ... thank you!
Hi @Chuck Tomasi ,
Its mention in service docs that the Locked Out users select box (TRUE) will terminate the user its not mentioned any where the user tried it many times wrong password then he/she will be locked out.
I think admin as has the authority to select the Locked Out check box true and terminate all the active session of that particular user.
Locked out : Select this check box to lock the user out of the instance and terminate all their active sessions. The system prevents users with the admin role from locking themselves out.
PF Link below of servicenow docs.
https://docs.servicenow.com/bundle/tokyo-platform-administration/page/administer/users-and-groups/ta...
