Difference between records.incident vs reference.incident? Flow Designer
10-03-2022 08:14 AM
hey all, I'm new to ServiceNow and I am currently experimenting with flow designer, particularly sublfow inputs.
I've been experimenting between the input types and I'm curious what is the difference between these two?
I currently have an approval action and I'm attempting to feed it the record that was created in another flow, but i cannot use the second input as the record in the approval action, but i CAN use the first reference record input.
i can see from the data pill that records.incident data type is 'records' but i cant seem to find anything in the docs about this data type.
10-03-2022 09:49 AM
Hello @kgomez222
Basic Diff is
Records.[Table] data type
Stores one or more Sys ID references to records in a specific table.
Reference.[Table] data type
Store a single Sys ID reference to a record in a specific table.
Harshad
