Discovery - Trouble discovering Fortinet APs, need advice
08-10-2022 11:52 AM
Trying to run Discovery on our Fortinet APs but I'm having trouble. The Discovery doesn't seem to be receiving much info from the device. Did an SNMP credential test against the device and that was successful. Here is some logs below. Any help is appreciated.
The Device results of the Discovery.
Here is the Discovery log
And the ECC Queue
Horizontal log is showing ports 161 & 162 (SNMP) are closed
Shazzam probe shows it's open
What are my next steps in troubleshooting this?
02-04-2025 02:29 AM
Hi Suusan,
Thank you so much for this. It worked like a charm. I was struggling from long time. Do you have same for Aruba WAPs as well?
Best Regards,
Kuljeet
02-04-2025 05:20 AM
No, we don't have Aruba WAPs.
02-05-2025 04:14 AM
No Worries, i created that. Thanks much for your response
04-22-2026 11:38 PM
@Kuljeet1 @SusanWinKY - where do you use this Extension? an existing pattern or create one for Forti, If we are creating one can you share the full Pattern please.
