Dynamically create checkbox using catalog client script
01-12-2017 03:52 AM
My requirement is to dynamically create checkbox using catalog client script in the "On Change" event of a select box.
I have a variable set (which applies to some service catalogs), in which there is a select box, which is populated using a REST API. When the selected value in the select box changes, a catalog client script should be triggered, and check box (multiple check boxes) should be created. The text of these check boxes will be populated from the response of a REST API.
Is this possible? I have checked the wiki and couldn't find a way to do this. I have tried for other variable types as well (like List Collector) but I couldn't find anything that can help.
Help is much appreciated.
Satheesh.
01-12-2017 05:41 AM
You can't dynamically create new variables. Your best bet would be a UI Page variable, where you could dynamically create new checkboxes in the UI Page. I don't have an example for you, but I would have a hidden checkbox in the UI Page that I copy for each value in the response, set the label and display. The hidden one in the page acts as a template.
01-12-2017 05:50 AM
Hi Chris,
The main concern/issue here would be if we use the UI Page and checkboxes will be created dynamically, but what if user selects 2 checkboxes and submits the request. The same 2 checkboxes should be shown as checked when user opens the RITM after submission.
06-20-2024 03:07 AM
Hi Ankur,
I have a similar requirement where I need a dynamic valu in middle of check box Statment..
Ex:- There will be a task included in this request that requires the <Support Group of the Business Application >
I was expecting the value of the support group of the business application replace the <support group of the business application>
Thanks in Advance
