emergency flow same as to follow for Release Issue Fix
02-24-2025 09:41 PM
Hi Team,
we have a requirement that , we are having ' Release issue fix ' change , it has to work like how emergency change request is working , same flow has to work in when we submit release issue fix request submitted .
can any one please provide the steps to completed this requriement .
if possible please provide screenshots of configuration for better understanding.
Thanks in advance
02-24-2025 11:24 PM - edited 02-24-2025 11:25 PM
Hi @nameisnani ,
For the created change model 'Release Issue Fix' does the type should be 'Emergency' or a new change type?
Provide the Model state transitions for the created change model.
02-24-2025 11:44 PM
Hi @nameisnani
This is a model, and its purpose is to function as defined by the user. If you want to make changes, copy the Emergency model, rename it to Release Issue Fix, and use it accordingly. This is the easiest approach.
Steps to follow:
- Go to Change Model.
- Open the Emergency Change model.
- Click Insert and Stay to create a copy.
- Rename the new model to Release Issue Fix.
- Deactivate the current model.
02-25-2025 07:19 PM
02-25-2025 11:24 PM
Hi @nameisnani
Look like it is a read-only model. To start, better create a new model, similar to the Emergency model. Follow the same configuration.
