Flow Designer: Copy Attachments Not Working
Eric Paul
I have a flow that triggers when a record is added to a custom table of mine.
When that record is created, the flow needs to create a new record in the sys_data_sources table, and once that new record exists, i need to copy an attachment from the trigger record and add it to the new record on the data sources table.
I continue to get the following error:
Here is what the flow design looks like currently:
Once i'm able to get this attachment added, then i'll be creating a custom action to effectively kick off this data being loaded as an import set and the loaded/transformed.
This is my first go with Flow Designer, so any help is greatly appreciated.  Thank you!
17 REPLIES 17
I realize this is an older post but I am having difficulty in copying multiple attachments using Flow Designer.  I am not a programmer and am relatively new to Flow Designer.  I have only managed to pull in one attachment.  Would you happen to have some screen shots you could share?
Mike
Did you ever find a solution to this question?
leachy23
Kilo Expert
Hey all,
I cant seem to find the Sys_attachment table in the 'lookup record action' table dropdown, any ideas why?
Bobby4
Cheers Bobby,
very useful!
