Flow Designer - Creation of Catalog Task issue
tindiz
Giga Guru
Please help. I created a Flow for one of our Catalog Item where once it's approve it should create a Catalog Task.
However, it is not working as expected. When I am logged in as admin it works but when I impersonate another user that is not admin it is not working. Catalog Task is not being generated. I cannot pinpoint what exactly the problem is.
I added an error handler and that shows up after the approval. It means it is not pushing through to the next step which is Catalog Task creation. This is happening when I am impersonating other user but it works when I am testing it as admin. Please help.
3 ACCEPTED SOLUTIONS
AniketZ
Hi @tindiz ,
Please check flow properties and set them as run by the system.
Saurabh _
Hi @tindiz
            Check once RUN AS for your flow under Flow properties. It should be System User.
Wow it works! Thank you!!!!!!!!!!!!!!!!!!!!!
Saurabh _
Hi @tindiz
