Flow designer - Data pill values not available in script mode
AEterni
Mega Guru
Hello All,
I have recently discovered that it is not possible to drag and drop data from the data pill values of the flow inside a script.
I hope you can help me with the following requirement.
This is the script we are using
**Access Flow/Action data using the fd_data object. Script must return a value.
**example: var shortDesc = fd_data.trigger.current.short_description;
**return shortDesc;
var pwvalue = new GlideappMaskedQuestion().decode(new GlideEncrypter().decrypt(fd_data._1__get_catalog_variables.password));
var encodedpw = new GlideappMaskedQuestion().decode(new GlideEncrypter("xxx").encrypt(pwvalue));
var output = {"FirmId":46,"EncryptedPassword":encodedpw,"AttachmentId":"b16829cd87d541903c1da6c73cbb350d"};
return output;
I would like to get
  • the "FirmId" from the company table and
  • the sysID of the attachment
For the "FirmId" we usually dot.walk using the data pill values (see image below), but it is not possible when are in script mode.
For the sysID of the attachment, do you know how I can get it?
The final script should look like this one.
**return shortDesc;
var FirmId = xxx
var AttachmentId = xxx
return output;
Thank you.
you want attachment sys_id for the RITM record?
if yes then you need to query sys_attachment with current ritm sys_id
like this
var ritmSysId = fd_data.trigger.request_item.sys_id;
var attachmentID;
var gr = new GlideRecord("sys_attachment");
gr.addQuery("table_sys_id", ritmSysId);
if (gr.next()) {
	attachmentID = gr.getUniqueValue();
return attachmentID;
So your final code when I combined above script is this
var companyID = fd_data.trigger.request_item.company.u_id;
var output = {};
var attachmentID;
if (gr.next()) {
output["FirmId"] = companyID.toString();
output["EncryptedPassword"] = encodedpw.toString();
output["AttachmentId"] = attachmentID.toString();
return output;
Please mark my response as correct and close the thread
16 REPLIES 16
the field on RITM table which refers core_company is company
so give this
var firmid = fd_data.trigger.request_item.company.u_id;
return firmid;
Indeed, this one works and returns the value.
return companyID;
If I try to add this to the original script I get I get this error message
{ "serialization error": "No serializer found for class com.glide.db.datamodel.ShortTableName and no properties discovered to create BeanSerializer (to avoid exception, disable SerializationFeature.FAIL_ON_EMPTY_BEANS) (through reference chain: java.util.HashMap["FirmId"]->com.glide.script.glide_elements.GlideElementNumeric["ed"]->com.glide.db.ElementDescriptor["shortTableName"])"}
var output = {"FirmId":companyID,"EncryptedPassword":encodedpw,"AttachmentId":"b16829cd87d541903c1da6c73cbb350d"};
return output;
try to send the object like this
var output = {};
output["AttachmentId"] = "b16829cd87d541903c1da6c73cbb350d";
return output;
Hey,
it works. Thank you very much for your help.
Is it too much to ask if you can help me with that last piece of the script to find the sys_id of the attachment?
I know that all attachments are saved in the sys_attachment table. I am trying this script, but it returns empty value
var attachmentID = fd_data.trigger.request_item.attachment.table_sys_id;
Thank you.
like this
var attachmentID;
if (gr.next()) {
var output = {};
var attachmentID;
if (gr.next()) {
return output;
