‎01-27-2022 05:08 AM
Hello All,
I have recently discovered that it is not possible to drag and drop data from the data pill values of the flow inside a script.
I hope you can help me with the following requirement.
This is the script we are using
**Access Flow/Action data using the fd_data object. Script must return a value.
**example: var shortDesc = fd_data.trigger.current.short_description;
**return shortDesc;
var pwvalue = new GlideappMaskedQuestion().decode(new GlideEncrypter().decrypt(fd_data._1__get_catalog_variables.password));
var encodedpw = new GlideappMaskedQuestion().decode(new GlideEncrypter("xxx").encrypt(pwvalue));
var output = {"FirmId":46,"EncryptedPassword":encodedpw,"AttachmentId":"b16829cd87d541903c1da6c73cbb350d"};
return output;
I would like to get
- the "FirmId" from the company table and
- the sysID of the attachment
For the "FirmId" we usually dot.walk using the data pill values (see image below), but it is not possible when are in script mode.
For the sysID of the attachment, do you know how I can get it?
The final script should look like this one.
**return shortDesc;
var FirmId = xxx
var AttachmentId = xxx
return output;
Thank you.
Scripting and Coding
‎01-28-2022 01:05 AM
you want attachment sys_id for the RITM record?
if yes then you need to query sys_attachment with current ritm sys_id
like this
var ritmSysId = fd_data.trigger.request_item.sys_id;
var attachmentID;
var gr = new GlideRecord("sys_attachment");
gr.addQuery("table_sys_id", ritmSysId);
if (gr.next()) {
attachmentID = gr.getUniqueValue();
return attachmentID;
So your final code when I combined above script is this
var companyID = fd_data.trigger.request_item.company.u_id;
var output = {};
var attachmentID;
if (gr.next()) {
output["FirmId"] = companyID.toString();
output["EncryptedPassword"] = encodedpw.toString();
output["AttachmentId"] = attachmentID.toString();
return output;
Please mark my response as correct and close the thread
‎01-28-2022 05:01 AM
It works. I can get all three details I need.
One last question (for real this time...I don't know how to thank you enough).
How can I remove the "" from the output.
{"FirmId":"182","EncryptedPassword":"xxx","AttachmentId":"b16829cd87d541903c1da6c73cbb350d"}
Thank you.
‎01-28-2022 05:51 AM
Don't remove those quotes.
Standard JSON request has that quotes in it wrapped around the value of json key
Please mark my response as correct and helpful to close the thread.
‎01-29-2022 11:33 PM
I believe I have answered your question.
‎01-30-2022 12:21 AM
Indeed
I left the "" in the JSON string and my infrastructure team will strip them out before feeding the string to the Azure Runbook.
Sorry for my late reply, I was off on Friday.
Thank you for your support.
‎01-30-2022 12:23 AM
Glad to help.
