Flow designer flow is not working
mania
I have created a flow designer for one particular catalog item. but once i raise a ticket from the portal that flow is not working. but once I test the flow that particular RITM record from the test flow its working.
But I want to be work from the portal too.
Can anyone please help on this. It will be usefull.
Thanks!
13 REPLIES 13
Hi @mania
Need to check the flow context and see where it stuck and then need to find the reason.
@Dr Atul G- LNG
Can you please tell me the issue.
Thanks!
Hi @mania
Here need the manual action, the task been created and you need to close / take action on task.
@Dr Atul G- LNG
Can you suggest the below one, It is showing evaluated false.
Thanks!
Could you please provide the flow screenshot of thsi
