Flow Designer Help Please
‎08-11-2023 11:21 AM - edited ‎08-11-2023 11:22 AM
Hi everyone,
I'm new to flow designer and am having difficulty setting the stages based on states. Initially I had both request and request item set to update but removed request to simplify things. If possible I would like to make sure both are the same. The problem is when I run a "test" the states /stages look like they are all processing correctly. However when I submit an actual request, all of the stages are getting completed. I've simplified this by rooming all of the "ifs" but one and it is still happening. What I am trying to acheive is to have an inital stage and state set. Then if the state changes the stage should also.
Attached are some screenshots to help explain.
Thanks so much for any feedback you can provide!
‎08-14-2023 03:08 PM
Hi Gemma,
You need to set the stages in the flow, you can create a new stages or you can use three dots button on the right corner to import existing states after that you move your mouse on flow, you get a grey line and you can add stages on that line, attached is the image for your review.
