Flow Designer - How can I access output variable from Script Step in f(x) script in a activity?
John_123_Snow
Mega Expert
Since ServiceNow lacks their documentation...I will have to ask here,
How can I access output variable in a Flow Designer in f(x) function of an Activity?
@John.123.Snow
Refer sample example below
1) My step 2 is custom action and it has output variable
2) how it can be used to fetch the output variable refer below
fd_data._2__list_collector_convert_to_array.variable
9 REPLIES 9
thanks, this works, BUT why when I return sysIDs of groups, it doesnt trigger the approvals?
Thanks for confirming that my solution of dot walking to the step worked.
what are you returning from the step 2
refer below link for reference on scripting ask for approval
Flow Designer and scripting Ask for Approval
@John.123.Snow
Let me know if I have answered your original question.
Please mark my response as correct and helpful.
Hi John - Don't use fd_data.trigger. It should be fd_data.THEN SELECT THE FIRST STEP ACTION (get catalog variable name). FOLLOWED BY VARIABLE NAME.
https://docs.servicenow.com/bundle/paris-servicenow-platform/page/administer/flow-designer/concept/i...
@John.123.Snow - Please let us know if you have any additional questions.
